Is injector upgrade worth while?
I hane'nt read much in the way of swapping out injectors for more flow. Is this not recomended, or can nice gains be made? I have only really dealt with carburated vehicles, so practically no real knowledge about fuel injection.
I am putting together my mod list, so any and all help is appreciated.
Thanks
Thanks
RE: Is injector upgrade worth while?
Thanks, but lets say you want to get to 350hp or there about, would a slight upgrade then be worth while. I'm considereing, steen stg2 ported PI heads, manifold, vt stg2 cams, full exhaust with headers, TB and plenum (75mm), and a good tuning.
At this pint do you think an injector upgade will get me anything? I am not a bigger is better guy, I learned on my 351c that you can over cam and over carburate and build a very expensive dog. But newer engines with injection are a different beast, and I don't want to starve the engine for fuel.
Again thanks
Again thanks
yeah at that point it'd be good. Once you get to 300 or more horsepower and you are still running stock injectors, they are working pretty hard, starting to reach their limits. An upgrade would prevent you from running lean or frying an injector
Thanks, I would also imagine that a fuel pump would be needed. Unless there is a regulator on these engines where I could tweek the fuel flow and preuure. I don't know too much about injection, but I know that the flow numbers are at a certain psi, ie 40#@ Xpsi. I would not make a huge change, so maybe stock pump would be ok?
Thanks
Thanks
ORIGINAL: Armydad
Thanks
Thanks
Thanks alot, great info, but I will polly not be getting to the 400 mark. This was supposed to be a nice weekend driver for me and my better half, but you know what happens. I will probably pull back a little with the mods. I'm thinking
headers (shorty) Ford Racing
Bassani catted Xpipes
Bassani cat back
C&L Plenum
Accufab 75mm TB
pulleys
PI intake kit ( Livernois)
cold air induction
chip and tune
That should put me right around 300-310hp with approx 310-320tq . I will probably not do heads and cams (yet)
Does this sound reasonable to you? Should I do something with the air mass?
As always opinions and info is much appreciated
Bassani cat back
C&L Plenum
Accufab 75mm TB
pulleys
cold air induction
chip and tune
I wish I had my shm book it says the exact horsepower cut off for the injectors. I have 24lbs injectors and 255lph fuel pump. They say after 350 horse to upgrade from 24lbs and move up to like 32 I believe.
