cam write-up
RE: cam write-up
i just did the install myself... they say you need a cam tool but you really dont.... the hardest part is getting either the valve covers off the car, or putting back on the timing chain onto the cam....
RE: cam write-up
well... this is how i did my cams..
i took off both valve covers.... pain in the ***.. you may have to remove other things to get them out
then i removed the cam gear bolts and slid off the cam gear with either zipties or something on it to keep the timing from being screwed up.
then i unbolted the cams and picked them straight out of the motor. i put the new cams in and bolted them down close to where they should be in timing... then i turned the cams till they were lined up with the cam gear and slid the gear back over the cam... this can take alittle work but its possible...
RE: cam write-up
ORIGINAL: racer02GTstang
I was thinking of this the other day. lol
I guess it works.
RE: cam write-up
So does this method really work??? Just zip-tie the cam sprockets to the chain and then re-install on the new cams?? Please give more details and post any pictures of procedure!!! I'm about to do this for my wife's 2000 GT. Thanks!
RE: cam write-up
ORIGINAL: dtkikols
so you dont have to take the front of the engine apart? as long as you keeping the timing chain zip-tied to the sprocket?
