diablosport
Old 08-31-2006, 07:19 PM
Cornbread01
Cornbread01's Avatar
Default diablosport
Well i got the tuner and put the diablo tune on and advance the timimg to 9 in both 2-4k and 4-6k and i can diffentally tell a difference on both the street and highway accelerates alot faster i am very happy.... and a plus is the data viewer if it is correct it answered my ???? about my tach and speedo being wrong after installing the white face gaudes my tach is off by 200 rpm all the way through and my speedo off buy 5mph all the way through so i have to correct it or buy a new cluster.... but the tuner i bleave is a must can do a lot with it if its a diablo or sct you must have one.
Cornbread01 is offline
Old 08-31-2006, 07:24 PM
red2k1gt
red2k1gt's Avatar
Default RE: diablosport
You might want to try and play with the needles on the gauge cluster first before you go correcting it with the predator.
red2k1gt is offline
Old 08-31-2006, 07:25 PM
Cornbread01
yea thats what im do and then check it with the tuner i must have put the needles on worng for it to be the same difference all the way though
Old 08-31-2006, 07:26 PM
chilledfresh
chilledfresh's Avatar
ORIGINAL: Cornbread01
Sounds good, I'm going to put in my tune after work. Did you take off your needles when you installed your gauge faces?
Edit: nevermind, just read your post. Are you using the diagnostics readout on the dash to check your RPMs?
chilledfresh is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
dubarado
12-23-2015 01:16 PM
t3000
05-10-2005 09:03 PM
dan
02-21-2005 02:00 AM
Diablosport
11-12-2004 11:26 AM
Quick Reply: diablosport
