Faster Auto Shifts?
RE: Faster Auto Shifts?
iF YOU HAVE A HANDHELD, YOU CAN LOCK THE CONVERTER AS WELL AS SET YOU SHIFTING FIRMNESS TO ALMOST MAX. YOU MAY LOOSE ALITTLE TORQUE, BUT GAIN IN IT QUICKNESS. i JUST HAD MY CAR TUNED W/ A SCT AND THEY LOCKED MY CONVERTER AND ADJUSTED MY SHIFTING POINTS/ AS WELL AS SHIFTING FIRMNESS AND IT RUNS REAL GOOD WITHOUT NO SHIFT KIT.
MY CAR CHIRPS IN SECOND LOUD AND PUSHES YOU INTO THE SEAT EACH SHIFT , EVEN DOING OVER 80MPH.
THE ONLY THING I DON'T KNOW IS IF THIS IS GOOD OR BAD FOR THE TRANSMISSION, BECAUSE IM SSURE LINE PRESSURE IS AT IT'S MAX. THE OTHER DOWNFALL IS THAT IT SHIFTS HARD IF YOU AT PART THROTTLE OR WOT. KIND ON ANNOYING WHEN YOUR CRUISING.
if you get a shift kit, get a Trans. Cooler too https://mustangforums.com/m_1890235/...m.htm#1890242;)
ORIGINAL: clix813
I was wondering is there any thing that i can buy that will give my gt auto faster shifts. i loose so much when it just takes it all the way to redline.
