Gauge Help
Gauge Help
Just received 2 auto meter gauges used, they are the ultra lite nitrous pressure gauge and the ultra lite temp gauge, did not receive any parts with them, except 2 bolt looking things, what else do i need to install these?? besides the pod, thanks
RE: Gauge Help
The temp gauge will go into the side of the block. As fas as the nitrous gauge, I only use them on the bottle. Oh and BTW, you can't just tap into where your stock temp gauge seding unit is on the intake.
RE: Gauge Help
Is your nitrous pressure gauge mechanical or electrical?? If it's mechanical, you have to run it from your nitrous bottle all the way to your gauge cluster. You'll need the longest hosing summit has, thats what I did. I think it was like 40 bucks.
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
