8.8" 4.10 31-Spline 5-Lug Torsen Rear End
I'm looking to buy a pre-assembled (ideal) or build a rear end. My budget is $2000.
Does anyone know if there is a kit similar to M-4006-S197 (Ford Racing Parts) for the 2004 Mustang?
If I plan on building it, here is the list of parts I have so far.
Do you notice anything else I'll need or any redundancies/conflicts?
M-4235-E - 8.8" 31-spline 5-Lug Axle ($225.99 from JEGs)
M-4209-G410A - 8.8" 4.10 Ring and Pinion Set ($199.99 from JEGs)
M-4204-T31 - 8.8" Torsen Differential ($484.95 from Summit Racing)
M-4010-A88 - IRS Housing ($528.99 from Summit Racing)
M-4413-A - IRS Bearing and Seal Kit ($21.88 Summit Racing)
M-4210-C (95.99 JEGs)
Ring & Pinion Installation Kit
Crush Sleeve, Pinion Seal, Ring Gear Bolts, Cover Gasket
M-4211-A (12.99 JEGs)
Case Gasket
M-4067-A (9.99 JEGs)
DIFFERENTIAL BEARING ADJUSTING NUT
M-4050-B (12.99 JEGs)
8.8" AXLE INSTALLATION KIT
Bushings, C-Locks, Friction Modifier
M-4034-A (31.99 JEGs)
8.8" BEARING CAP STUD KIT
M-4033-G1 (164.99 JEGs)
AXLE GIRDLE
For a subtotal of: 1790.74 (plus tax, shipping, and labor if I plan on taking it to a shop).
Case Gasket
AXLE GIRDLE
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
