Help with starter motor
Hello guys. Im right in the middle of working on my friends 03 Gt. We are putting in some bbk long tubes. I have x-pipe disconected at the cat back part and on the driver side. My problem right now is I cant get the starter mortor off. I got the one lower bolt off and one upper one. How many bolts are there? The motor does not want to move so I guess there is one more. Any pictures,diagrams or write ups would help. Thanks a lot!!!
RE: Help with starter motor
ORIGINAL: 97targa
There should only be two bolts!!! One pain in the *** top one and pne lower one. The starter may be wedged. Try turning the motor with a wrench by hand.
Thanks a lot. Yeah that top one was no fun. Good to know there are no more bolts. Bad thing is the starter will still not come off. How do you turn the motor by hand? I tried shaking and pulling on the motor but it would not come off. Thanks again.
ORIGINAL: Cornbread01
there is an easy way to get the starter off if you have about a foot and a half of extensions you can get the straight on through a gap by the k-member very easy to get both bolts
RE: TRY PUTTING IT IN NUETRAL!!
Yeah what the title says....nuetral that's if it's a stick. If you jacked it up in gear and the back tires are on the ground you prob. have a lot of pressure on the flyewheel with the clutch.
ORIGINAL: 97targa
Also does anyone have a guided to the install? Its not rocket science but a few tips here and there could help out and pics would be a plus. Thanks a lot for all your help
