Throttle hang fix - RPM's don't drop
RE: Throttle hang fix - RPM's don't drop
ORIGINAL: Fallstar01
Why would it help in a speed contest?
ORIGINAL: UhadMEatGT
Why copper??
Why copper??
I have a 1998 GT and my car does EXACTLY what you are talking about. I have an automatic and when you slide it into neutral or when it is in park and you rev it up it takes FOREVER for the RPMS to come back down. It sounds really unnatural and retarded. I have always wondered if it is just my car or if all 96-98 4.6L Mustangs do it. My buddy has a 2003 GT and we compared and his seems to rev pretty normal. If anyone knows what I'm talking about please let me know!
this probably isn't whats wrong with yours but, my RPMs where hanging after i switched my gauge faces, but mine was because i put the need on too tight............. but if you haven't taken your needles off then your problem probably lies somewhere else
Look at your throttle body. See where the black hose brings air from your intake into your throttle body? That's how the computer feeds air above and beyond what your butterfly opening is currently doing in order to keep transient RPM's from ruining emissions / mileage I think. Anyway, there is a plate with two bolts where the rubber hose goes into the throttle body. If you make a restrictor plate to fit in there you can restrict how much air is available to hang your RPM's. We made my plate out of thin siding like metal material. There is some debate on what size hole to drill. If you restrict too much air, your computer will have a hard time idling your car like when it's cold out (1000 rpm). If you restrict too little air, then you simply won't eliminate your throttle hang. Apparently we did a good job on mine cuz mine can still idle at 1000 rpm when it wants but the hang is very much reduced. Search for IAC plate. There is even a drawing out there. If I get time, I'll take mine out or take pics but it is a little pain and I'm a little lazy.
