Supercharger and 4.10's ????
Old 09-05-2006, 09:04 AM
jjfrehe
jjfrehe's Avatar
Default Supercharger and 4.10's ????
Hello all - I have a 2003 GT (Auto), and am getting pretty close to making the jump into a supercharger. The primary concern I have is if the 4.10's are too much gear to use with a S/C. Anyone use or have tried to use this configuration?
jjfrehe is offline
Old 09-05-2006, 09:25 AM
VARifleman
VARifleman's Avatar
Default RE: Supercharger and 4.10's ????
I think it is trueblue or something like that has 4.10s running a 9psi KB blower. He said it's real fun on the street but on the strip he just spins and if he didn't, he'd run out of 4th gear before the end. Keep in mind though that you could go to a taller tire (lets use a 28 instead of the 25.6 diameter that's the stock tires), if you notice that the gear is too much for your purposes. Running a 28 in diameter drag radial or slick in the back instead of a 25.6 in diameter street tire means that your gear ratio would drop from the 4.10, to a 3.75. You will probably want to have adjustable lower control arms then to make sure you don't squat down on the tire.
The two things that determine what gear ratio you should go with is power, and use (ie speed you want the most power or torque).
EDIT: the guy's name on here is Blue70
VARifleman is offline
Old 09-05-2006, 09:28 AM
nanaki
Retired MF Moderator
nanaki's Avatar
if it's a centrifugal, i'd say go with the 4.10s. i think bicketybam was running 4.10s with his vortech and had no problems. i'm running 3.73s and want to jump to 4.10s.
nanaki is offline
Old 09-05-2006, 09:45 AM
stang2000
stang2000's Avatar
I'd say stick with 3.73. You want to be able to shift at higher rpms to get the most out of the SC. If you get 4.10's, you're shifting sooner and not getting the benefit from the boost of the SC.
stang2000 is offline
Old 09-05-2006, 09:54 AM
mikev08826
I ♥ Acer
mikev08826's Avatar
Dude that's awesome. I'm SERIOUSLY considering giving Modular Powerhouse a jingle today.
mikev08826 is offline
Old 09-05-2006, 11:51 AM
Mt Twigbert
Mt Twigbert's Avatar
I have 4.10s and a Centri SC.. Once I got a good set of DRs I got no issues at all..
Mt Twigbert is offline
Old 09-05-2006, 01:21 PM
jjfrehe
jjfrehe's Avatar
Thanks for the feedback guys. I think I'll try it with the 4.10's and see how she drives.
jjfrehe is offline
Old 09-05-2006, 02:50 PM
LvGordo
LvGordo's Avatar
ORIGINAL: Mt Twigbert
with the kinda power you have, i find that hard to beleive. you must have great roads where you are at.
LvGordo is offline
Old 09-05-2006, 03:13 PM
CobraSnake
CobraSnake's Avatar
ORIGINAL: LvGordo
accually this is true every realative of mine that comes to my house says that once they hit wisconsin they roads are awesome. I don't know about some of them but, most of them are good.
CobraSnake is offline
GimpyHSHS
19
12-19-2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Supercharger and 4.10's ????
