went to auto zone, got some Sea Foam and...
RE: went to auto zone, got some Sea Foam and...
they is a line into the plenum, it has some cables in it, and this is my first time, my friend does it before every oil change, he said that it fixed a ping (or something like that) so he is in love with this thing, i guess ill doint every oil change too since now
The stuff is really great I have only used it in yamaha blaster waverunners,the **** will clean up jets and ports in seconds,great stuff for storing your car too only thing that sucks is now everybody knows about the **** and the price is sure to go upp Gary99gt
how much was the seafoam?? i am also going to do it soon wahooo... so where are the main spots i have to put the seafoam in[&:] just want to make sure i put it in the right spots thanks
Your PCV is located on the passenger side, the cable going from the plenum to the valve cover. Just stick the boot of the cable at the tip of the open can and slightly tilt the can. The line will suck it up very slowwwly. Be patient because if you let it take too much, your engine will stall.
it's like 7 bucks in auto zone, the easiest spot to use is this one... just take that rubber hose out, while the car is running make sure you have someone to give some gas so you dont stall the car, the easiest way to do it is coupling a hose (home depot) and let it suck the liquid another way is a cup and a straw, it will suck it right away, then the rest in the oil and the gas tank
[IMG]local://upfiles/30744/68BE55B8618542C0917719A3392B5611.jpg[/IMG]
[IMG]local://upfiles/30744/D9EED239524240468885058240D8B3AF.jpg[/IMG]
[IMG]local://upfiles/30744/3073EDA4C583429F83A814C960AEF419.jpg[/IMG]
