Mac TB/plenum and K&N CAI question
Hey ya'all, as In my subject line, I just bought a Mac 75mm TB/Plenum and a K&N CAI first mods I have ever bought, my question is, is there anyway someone could link me to a good website with pics of what bolts to take off for sure, I would like to learn how to do it. .or where in the manuel I should look if its in there? or even post pics or information on how to take off the TB/Plenum, I will be putting both on at the same time obviously. any information would help thanks!
and second.. is the MAC TB/Plenum good? got it used for a good deal, and is there anything I should look out for with it? any info would be great
RE: Mac TB/plenum and K&N CAI question
well changing out the upper plennum is really sself explanatory but well there are 5 bolts that i believe are 8 or 9mm that hold the actuall upper plennum on and then the 2 bolts on the egr which is on the driver side the only thing over there that is brobably a bit rusty since it has nothing on it and then just make all the wire connections and hoses which really only will hook to one thing and oh yeah you have to swap out the iac valve which is on the very front which has 2 bolts in it as well and those are like 8mm also really easy but if you have a haynes manuall that will help alot with it as well just don't over tighten the upper to lower plennum bolts since you are screwing into a metal insert in plastic that would be bad but good luck it is really very easy
another questions I have is...
is the MAC 75mmTB and plenum any good? I am seeming to have a hard time finding much info on it. and what I do find is that its cheap?
