intercooler.//
#21
RE: intercooler.//
in the last video race, vs the gt, which tires did you have on? did your traction correct with the radials?
and the ls1 race.. is that the same car as a ss?
im not doubting the power of the vortech. but does it kick in off the launches? so say im droppin into 1st from a dig at like 3500rpms, will it launch powerfully (with the radials) beeing fed by the vt? which is the best vortech out? i notice different versions- is it just the noise levels?
#22
RE: intercooler.//
Not to "Nut swing," or sound like I'm teaming up here, but c'mon...
No offense, but do you honestly think you're not going to notice an extra 100+ horsepower?? That's f-ckin nuts to think otherwise...
Personally, I'm going the Vortech route.. I've had one before, and I'll have one again. Power comes on almost immediately, and it lasts through the power band for the most part.. Although, this time I'm going to Dyno tune it, instead of "Seat of the Pants," tune it, like I did when I was 19...
KB isn't the only S/Cer out there... Some on here tend to think so though..
JT
JT
#25
RE: intercooler.//
ORIGINAL: dvs_03gt
All LS1 cars are "the same" as a SS. The SS package is a joke (at least from a power/drag racing POV), ask any of the LS1 guys, they all dyno and run about the same. BTW, you should see me race him from a dig or slow roll. On the video there I was basically putting him away and then getting off it. From a dig or slow roll it is simply utter murder, never see him again.
My car launches real hard now. Thats one of the advantages of a vortech, it doesn't make a crapton of torque at 1500 RPM and blow the tires off. But either blower you can launch pretty hard, its all in your technique and practice. Like I said, that was literally the first time the car was WOT on the street from a stop.
The differen't levels of vortech are differen't designs and power levels. I recommend at LEAST the V2-SQ (its the new design entry level, you can get it S or SQ, the SQ is quieter at idle). If you plan on staying with the stock shortblock get the V2 S or SQ, if you plan on rebuilding the engine get the T trim, its a little more money but has more power potential.
stangy004- The KB systems use an air to air intercooler underneath the blower. It fits under the blower where the intake manifold used to be, and the blower pushes the air thru it, and then into your engine. It is connected to a pump and what is baisically a radiator which flows fluid thru the intercooler, then out to the seperate radiator to use air to cool it off.
#27
RE: intercooler.//
ORIGINAL: dvs_03gt
do u think ill need to replace my tranny? the 3650 shifts clean if i take my time with it.. you think things will be fine?
I don't recommend that, but if you avoid real hard shifting it should hold up for quite some amount of time.
on the other hand, I broke 2 45s with 280 WHP...
#28
RE: intercooler.//
lol.. i figure if i drive it right i should be okay? fk. i just hope not to spend 4 grand on a s/c to find i blow my tranny.. bc i doubt my ford warranty will replace it with the s/c on there hahah.
anyhow i still have not decided on my s/c choice.. and this sucks.
#29
RE: intercooler.//
MD was even running slicks with a built 8.8 rearend, so I think with drag radials and not going crazy with powershifting you should be fine for awihle.
Anything can happen, but the stock trans should not have any problems taking that power level.
#30
RE: intercooler.//
good to know.. other than that.. the mongoose kit u have, what else does one need to purchase for it? and how much more would an intercooler be w. it? what diff. would the intercooler make?
the sq and the s.. the sounded noises are different how? like on the gas does it whistle??
