Pi Swap/ what cam?
Old 09-08-2006, 12:12 PM
01BlueCobraVert
01BlueCobraVert's Avatar
Default Pi Swap/ what cam?
According to Comp Cams I can only use a .500 lift. Another person told me .531 w/ a custom grind. Anyone who has done the swap and aftermarket cams, what did you use. I need to get the cams in a week and I am worried about PTV clearance issues. Thanks
01BlueCobraVert is offline
Old 09-08-2006, 01:28 PM
firstonraceday96
firstonraceday96's Avatar
Default RE: Pi Swap/ what cam?
Alot of people just use the stock 99+ ones.
firstonraceday96 is offline
Old 09-08-2006, 01:42 PM
01BlueCobraVert
I want aftermarket. I have ported heads.
Old 09-08-2006, 01:45 PM
2000GT4.6
2000GT4.6's Avatar
Give VT a call and tell them what you have and what you want for a idle etc, and they can point ya in the right direction.
2000GT4.6 is offline
Old 09-08-2006, 01:52 PM
amoosenamedhank
amoosenamedhank's Avatar
I used a cam with .500 lift. I had to notch the pistons because I had valve to piston clearance issues. That is a MUST to check with the pi swap w/ aftermarket cams! You don't want to get that thing together and have a valve kiss a piston.
amoosenamedhank is offline
Old 09-08-2006, 01:54 PM
01BlueCobraVert
Yeah I know That is why I am so concerened. DO you know what your duration was? I am looking at 230/236 and a RPM range of 1800-5800.
Old 09-08-2006, 02:04 PM
amoosenamedhank
I seriously am have a big brain fart here. I think the duration was 230 on both at .050 lift. Now looking back I was I would have done a lot more cam. I was afraid to spin it past 6k but truth be told you can set a rev limiter so you don't rev past 6k until you upgrade parts. Now I'm just stufck with a "weak" IMO cam
Old 09-08-2006, 03:11 PM
DRWStanley2002
DRWStanley2002's Avatar
When I was checking into this for my 98 GT I called crane and they told me to use crane part # 379611.
DRWStanley2002 is offline
Old 09-08-2006, 08:00 PM
droptoppony
droptoppony's Avatar
Go with VT Engines stage 1 or 2 cams...please degree the cams in properly to avoid PTV and get the most HP out of them.
droptoppony is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Pi Swap/ what cam?
