HELP, UNDERDRIVE PULLEYS, THERMOSTAT
Old 09-08-2006, 05:36 PM
xX02MustangGTXx
xX02MustangGTXx's Avatar
Default HELP, UNDERDRIVE PULLEYS, THERMOSTAT
I bought a 160 degree thermostat and a some bbk underdrive pulleys. does someone have install guide for them, i put the thermostat in but the gasket was ridiculous to do and i dont know for suer if i did it right. Cause i kinda got it on but then i just tighted the top of it down pretty tight and there seems to be no fluid leaking.... HELP THO.
xX02MustangGTXx is offline
Old 09-08-2006, 06:09 PM
tcuallstar
tcuallstar's Avatar
Default RE: HELP, UNDERDRIVE PULLEYS, THERMOSTAT
you need to adjust your fan settings or else the thermostat isnt gonna do anything, infact its gonna do more harm than good
tcuallstar is offline
Old 09-08-2006, 06:52 PM
fishyducky
fishyducky's Avatar
can someone explain how the thermostat works and all that would be required for an install. i am quit interested on putting a 180 in the mach but dont know how to change the fan settings and all
fishyducky is offline
Old 09-08-2006, 07:04 PM
JPGT_00
JPGT_00's Avatar
As far as your pulley install I beleive there is a Sticky on it, Its pretty easy your going to need a impact gun, and a puller for your crank pulley but its pretty easy.
I like the Mach, thats a bas *** color
There is a sticky on it, Its under Tech 4.6. just scroll down and its for steeda pulleys but im sure its the same.
JPGT_00 is offline
Old 09-08-2006, 08:15 PM
xX02MustangGTXx
how do you change fan settings?
Old 09-08-2006, 09:44 PM
ShadowDrake
ShadowDrake's Avatar
Hand-held tuner would be the simplest, and the way I KNOW works.
ShadowDrake is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
spdeplayer2
10-24-2015 09:45 AM
GimpyHSHS
09-18-2015 12:27 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: HELP, UNDERDRIVE PULLEYS, THERMOSTAT
