Throttle body upgrade
Hey Guys,
Well my eyes are dead set for my next upgrade. I want to get an Accufab throttle body.
i have only two questions..
should i save me money and get the throttle body and plenum or just get the throttle body....
For record.. im getting the 75mm
when i get a 75mm throttle body will my k&n intake system fit on the throttle body perfectly like it does now or am i going to have to rig something together to make it fit corectly.
thanks justin
thanks justin
RE: Throttle body upgrade
ORIGINAL: yellowjacket01no it should fit up perfectly i have a 75 and it mounted up perfectly to the cai,also get the plenum as well,you might as well get the whole package.
I just aded a BBK 75mm TB & Plenim and got no noticeable on the timer I use to tune on the street with.
The timing adjuster is the best bang for the buck IMHO. New they are $140. Mark
PS: My JLT CAI coupler fit on the 75mm TB OK.
its point less if you have a 75mm opening drop down to a 65 mm at the stock phuluem if you can only buy one now do that and then buy the other put on at same time
ill spend the extra money .. im going to get the accufab throttle n plenum 75mm now is that easy bolt off then on or is it a pain .. i mean i know a decent amount of mechanical work but im a body work guy so is it easy .
EASY!
1. 2 EGR bolts, plenum to manifold, 5 bolts, also remove the throttle cable and mount, 2 bolts and cable, A couple of electrical connections and the hoses that go to the intake hose. Just did my BBK asembly about 10days ago. The plenum to manifold is a simple rubber ring but shaped to the intakes odd intake flange. Just reuse it if it isn't cracked or rottrd in any way buy I doubt you will need one and my BBK set-up came with 5 new allen head bolts for securing the plenum and the TB came with the gasket. Mark
JDWalton
09-24-2015 08:47 PM
