engine help..
Old 09-13-2006, 07:57 AM
dvs_03gt
dvs_03gt's Avatar
Default engine help..
I noticed tonight after driving, when i closed my door i heard a tshhh. it was some i think over flow steamy hot water im guessing? it was just dripping barely.. is there anything i should worry about? or is that normal overflow????
dvs_03gt is offline
Old 09-13-2006, 08:02 AM
1BAD3V
1BAD3V's Avatar
Default RE: engine help..
Dude, that same exact thing happened to me just a couple of days ago, its the first time I've ever heard it myself, I hope its nothing to worry about.
1BAD3V is offline
Old 09-13-2006, 01:07 PM
98MustangSTL
98MustangSTL's Avatar
Dude...I have the same thing. It usually happens after it rains or when I use the a/c. I really have no idea what it is, but I've just kind of brushed it off. I'd like to know what it is though.
98MustangSTL is offline
Old 09-13-2006, 01:11 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
If your coolant levels are all fine, it's more than likely just condensation from your AC landing on something very hot.
Dan04COBRA is offline
Old 09-13-2006, 01:13 PM
gtzx
gtzx's Avatar
If it is only when using the a/c then it is probably just the condensation driping onto you exhaust pipes because that happens to me all the time and have confirmed that it is just that.
gtzx is offline
Old 09-13-2006, 02:15 PM
avlon06
avlon06's Avatar
if i sprayed water into my tailpipes when i was washing my car, will it eventually just dry up the water? cuz my check engine light came on...
avlon06 is offline
Old 09-13-2006, 02:22 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: avlon06
why would you do that? If you shot enough water in there you probably just ruined the 02 sensors not to mention you're just asking to burn out your Cats...
Derf00 is offline
Old 09-13-2006, 02:29 PM
avlon06
avlon06's Avatar
its not like i put the hose up there, just some water got up there when i was getting the back.
avlon06 is offline
Old 09-13-2006, 02:42 PM
II 98 GT II
II 98 GT II's Avatar
The water will come out of the exhaust next time you get on the throttle a little bit. But yes, the damage already has been done if the check engine light is on.
II 98 GT II is offline
Old 09-16-2006, 12:56 AM
avlon06
avlon06's Avatar
really like what kind of damage are we looking at?
avlon06 is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: engine help..
