pulleys
pulleys
my friend gave me a set of pulleys for my b-day and he didnt tell me what brand they are. they are stainless steel. i want to make sure they are not the piggyback ones. i attached some pics. also, he bought them for his 2000 gt, will they fit my 04?
sorry for the huge pic
RE: pulleys
ORIGINAL: mattmoto441
1996-00 (Early Design 2000) Mustang 4.6 GT & Cobra 3-Pulley Kit
129-1555
Identification Guide for 4.6L Water Pump Pulley's
You should visually identify which pulley/pump you have before ordering regardless of model year! Mid-way through the production run for the 2000 model year Ford changed the design of the water pump on the 4.6L engine however the change is apparently based on the origin of the engine and is not specific the model year. The early style pump had a longer shaft. The later design of the pump was changed to a shorter shaft. This necessitated a change in the design of the pump pulley. Read on. The early water pump pulley had a convex or 'bowed-out' face and the later design has a concave or 'pressed-in face'. There is no exact changeover date for the pump and pulley. It is important to visually inspect your car to see which design you have. Supposedly the changeover occurred in January of 2000, but we have seen cars with identical January build dates and different water pumps and pulleys. We have also seen the early design pulleys used on a few 2002 models, so be sure to check your vehicle before ordering.
Refer to the pictures below to determine which pulley design you have. Since there is no definitive answer as to the time line or model years, we will refer to the pulleys from each manufacturer as early and late design.
EARLY style
LATE STYLE
hope that helps you out
129-1555
EARLY style
LATE STYLE
RE: pulleys
129-1555
EARLY style
LATE STYLE
129-1555
EARLY style
LATE STYLE
RE: pulleys
If you have a 04 then you have the Late style yes, but the pulleys that your friend gave you are the ealry style. and yes those are piggy back style. So they are pretty much worthless to you man, sorry
