Replace 4.6 with a bigger motor?
Is it possible to take out the 4.6 and replace it with a bigger crate motor? I'm not sure what all motors there are that i could put into the car but i was wanting to put a bigger motor (350+ci) and new transmission also. I was just trying to get some help from you guys as of what some options could be. I can't spend over 4k for a motor cuz i have to keep some money for the tranny and whatever else will need replaced. I have a 01 GT right now i was going to sell it and get an older GT like a 96 or maybe a 94 5.0 or something and replace the motor with a bigger one, tranny, ect. please help me out i'm trying to get the fastest motor/car for cheapest $.
Thanks!
Thanks!
RE: Replace 4.6 with a bigger motor?
Thanks man, do you have any idea or suggestions as of where i should look at them? i have been searching google for them and different websites. Found a couple for 4500 or so.....
And can you just drop this motor in or will there be some issues with the install and everything lining up do you/anybody know?....
Thanks.
Thanks.
You can put any sized engine you want in there. You will need new mounts, tranny possible. I would try local speed shops. I work for Roush and was looking for one a while back used. Found it for $5k 342RE, 440HP stock all motor. Also a company, RCG up in michigan. Builds great ones for about $7
thanks alot guys, would i be better off buying a motor used or new? money wise...is it worth it to buy it new out of the box?
What if i found a Chevy 454 or something would that work in a mustang? (probably alot of work to do i'm assuming.....)
five point four, four valve.
That would be the -simplest- swap to more displacement... the 5.4 sure makes good enough power (if you can find a set of '00 Cobra R/Ford GT heads, add a little twin turbo and you'll see 1000 RWHP [&:]), even the modified C heads that are on there are pretty darn great... While you'll be able to make more N/A with a larger motor, the 5.4 should be able give you everything you want and the swap will be amazingly simple.
Gary Ugarek
09-05-2015 09:03 PM
