mach 1 shaker hood noise???
RE: mach 1 shaker hood noise???
I had this problem a while after I installed the shaker extention, there is an easy fix, Under the shaker there are 4 teflon posts that support the shaker, these posts insert into 4 rubber bushings on the bottom of the shaker assembly, you can just replace the 4 rubber bughings, or what I did was went to an auto parts store and bought a tube patch kit and trimed the rubber patch to fit in the rubber bushing to take of the slack.
Total cost 2.99, time to do was about 45 mins... hope this helps..
desertmach thanks for the advice i will try it out soon. i know the shaker is not suppose to sound the way mine does because this link:
http://www.mustangheaven.com/forums/...p?threadid=494
ORIGINAL: MaChUBAN1
