exhaust rattle
Old 09-19-2006, 02:39 PM
DaMach04
DaMach04's Avatar
Default exhaust rattle
So i have been having this annoying rattling noise comming from the right rear of my car for a while, and i finaly got totaly annoyed with it, so i decided to crawl under there and take a look.
I found something kinda interesting. Where my exhaust bends up to go over my rear axle, for some reason it is rattling/vibrating on the side of one of my frame rails...
I cant figure out why it is doing this. I have had my Bassani for over 2 years now, and it just started doing it. I checked all the clamps and hangers (that i could find) and nothing is broken, or needs a bolt tightend. But for some odd reason, my pipe is not on tight. I started to move the pipe and it is loose at the muffler, yet the clamp around it is as tight as can be. I dont understand why it is so loose when the clamp is as tight as possible...???????
DaMach04 is offline
Old 09-19-2006, 02:42 PM
korn253
korn253's Avatar
Default RE: exhaust rattle
did u check ur exhaust tip, the hanger on ur exhaust tip actually helps hold that in place. mine got alittle loose and it was becuz the bolt holding the exhaust tip hanger to the tip got loose and fell out
korn253 is offline
Old 09-19-2006, 02:47 PM
DaMach04
DaMach04's Avatar
yes, it the the hanger right above the tip? tucked behind the rear bumber? I checked that one, and it was ok. That is what is messin with my head, cause i cant find any reason for it to rattle like it does...
DaMach04 is offline
Old 09-19-2006, 02:52 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
ORIGINAL: DaMach04
[sm=icon_rofl.gif]
what is the actual part that is rattling?
redass02gt is offline
korn253
korn253's Avatar
if u try and move the exhaust tip does it move? if its not a tip thats welded on maybe the bolts hold the tip to the pip is loose, if its not that trhen idk, id say take it to a muffler shop, they wouldnt charge that much to fix what ever the problem is
korn253 is offline
Old 09-19-2006, 02:56 PM
DaMach04
DaMach04's Avatar
ORIGINAL: redass02gt
ORIGINAL: DaMach04
[sm=icon_rofl.gif]
the exit pipe, the pipe that comes out of the muffler, and over the axle, and out the back. It is all one pipe, and it moves. The hanger is good, and the clamps are tight....but it still moves...
DaMach04 is offline
Old 09-19-2006, 02:59 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
is it actually loose where it connects to the muffler or just not held tightly onto the car? maybe the welding to the muffler is screwed up?
Old 09-19-2006, 03:12 PM
ChrisZio04GT
ChrisZio04GT's Avatar
I had same problem with my LM2s after i installed my xpipe.
took long pry bar and bent the hangers, no more rattle ever!!
ChrisZio04GT is offline
Old 09-19-2006, 03:15 PM
DaMach04
DaMach04's Avatar
it is hard to explain, you have to see it, but the pipe is loose at the muffler...but there are no welding craks, it is a brand new muffler (cause my old ones had a crack in them). And the clamp is tight, and hanger is fine...
i might have to just try to g-rig it myself
DaMach04 is offline
Dokilar
15
10-16-2015 08:13 PM
09-30-2015 12:39 PM
UrS4
09-30-2015 10:13 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
09-24-2015 09:18 PM
Quick Reply: exhaust rattle
