fuel injectors
RE: fuel injectors
You will only need a larger fuel injector IF you need more fuel. I.e. forced induction. However, if you can really push the limits N/a many people upgrade to 24lb injectors. The pound rating refers to how many pounds of fuel it can push/flow per hour. In metric sizing these are measured in cc's.
As you get more boost or air into the motor, you need more fuel for combustion. Hence why you must upgrade to larger injectors and/or fuel pump. Not too tough of a concept and not HIGHLY advanced, but this is a basic idea.
It gets really in depth when you get into air/fuel ratio, injection mode (sequential or batch), pulse width, volumetric efficiency, etc, etc.
RE: fuel injectors
Thanks for the reply lol, someone finally. So with larger injectors I guess gas mileage is DEVASTATED right? (assuming people really care about mileage with a supercharged mustang).
RE: fuel injectors
ORIGINAL: handyandy
mrappe
09-26-2015 10:16 AM
