My pulleys arrive tomorrow, install questions.
Hey everybody, as the subject says my Steeda pulleys come tomorrow, and I have a few questions. I know that a pulley remover is required, but are there any other special tools needed? Have you all experienced any problems during installation? Is this an easy install or is it a pain in the ***? Thanks for the help! Clay
RE: My pulleys arrive tomorrow, install questions.
Its easy, your prob going to need a impact gun to get the alternator bolt off,, there may be a way to do it, I dont know. but its pretty easy. I think there is a sticky on it, you can read over and get an idea.
ORIGINAL: powerslave_clay
get the crank/ damper puller from autozone it works great and its cheap. DO NOT get the GEAR puller!!! you will also need a 18mm socket that you can get there too. its not that hard, be sure to write down your belt routing!!
