Fuel Pump?
Fuel Pump?
I have a 98 GT with 92k miles on it that is pretty much bone stock besides a catback kit. Lately, when I start my car I notice that it takes literally anywhere from 2-3 seconds to start it up. This is a long time compared to the half second it used to take to start it. I figured the cars 92k miles on it and didn't really give it much thought until this morning. I went to turn on my car and it fired up but then immediately shut off. I tried starting it again and it finally started after about 2 seconds. What could be causing this? Is this electronic fuel pump going bad?
RE: Fuel Pump?
Yes, try a new filter first if you haven`t already. You can also turn the key to the on position then turn it off. This primes the pump. Then start the car. See if that helps it start any better. But 2-3 seconds isn`t bad. Im sure the pump is fine. I had my fuel pump going bad with my other car and the on/off thing with the key helped it start faster. I had to do it 3 times though. After having to do that for a couple weeks, I replaced the pump.
RE: Fuel Pump?
Well my 97GT had been giving me pullin problems and the long start up times as well
sometimes it would pull and sometimes it wouldnt when it wouldnt pull sometime the car would feel like it downshifted then when i would press the gas pedal it wouldnt raise rpms then it would just pull like crazy
the problems got worse and worse
then:
well i thought the problem was the stock plugs and wires at 83K miles so I replaced them with NGK plugs MSD wires and MSD coils
and the car was idling for about 3 minutes and then died and i havent been able to start it back up since
we tested the spark and it is great
so im gettin air and spark so is the fuel pump that finally died or what?
then:
RE: Fuel Pump?
ORIGINAL: ford88
yeah as in acceleration
and filter im guessing air or fuel
my air filter is clean
but it wont even start up now
RE: Fuel Pump?
ORIGINAL: ford88
could that really be the problem of it not starting?
no its not been changed the person who had it before me didnt do anything
mrappe
09-26-2015 10:16 AM
