New Here, with a few starter q's
#21
RE: New Here, with a few starter q's
Its not the boost thats hard on the engine, its the cylinder pressure. Boost is kinda directly related to cylinder pressure, but there are alot of other factors. Generally 8 psi is considered the max "safe" amount on the rods, but alot of people feel 10 psi is ok as well. Sure there are some people running more boost, even 14psi on a stock block, but the rods are just powder'd metal cast weak rods that will bend or break under too much pressure - especially when you combine pressure + rpms.
Alot of people say you can run more boost with the KB than a centrifugal supercharger (like vortech) because the boost comes in faster and you don't rev as high as the vortech units. You can honestly run damn near 500 hp on the stock rods and a safe tune as long as you keep the revs down. On the stock rods NA their said to be safe till 6500, with a 400hp car their not safe past 6k.
#25
ORIGINAL: nomocobra
ive heard the opposite md, since the kb boosts instatly, it creats a sudden strain on the motor. while on other hand, the centrifugal builds up, and is easier on the motor.
#26
ORIGINAL: mdvaldosta
It may be that way with the pistons nomo but its not that way with the rods, its more hp at higher rpm's that are hard on rods - and the rods are the weak link in the mod motors (assuming a safe tune for the pistons's sake). The cranks virtually NEVER break, and the pistons only really have trouble with bad tunes, so the rods are what I'd be worried with.
#27
I guess I should have said something like 14# is too much to run safely or for very long. Even with a great tune, I don't think you would run too long be bending a rod at 14#. Of course if you beefed up the bottom end and have a good tune, 14# would be fine, but upgrading your rods and pistons is definitely a different story than stockers. Sorry if I wasn't clear.
#28
ORIGINAL: 2002stang
Thanks everyone for the welcome... Much better than the import community.
Is it ok to boost the 4.6 9psi safely? I do commute 50miles to work everyday, so would it be ok if i dont drive it like a nut all the time?
As far as the midpipe, Ive seen several different kinds, Ive seen the bassani on ebay, and the macs for cheaper on ebay. I had never heard of mac but i didnt want to bid on it off ebay not knowing if it was a no name or not.
Ive seen the vortech kit without the powercooler go for 2k on ebay, which i think is fairly decent Considering I could whip up on some cars. I hear everyone phraseing gearing. Could someone Explain what the Pros and cons to the gearing is?
Thanks again
Anthony
Thanks again
Anthony
The cheapest way to make your car run high 12's...
Rip off the exhaust after the headers. Remove the silencer and put a K&N in there. Get a cheap, basic bottle of nos, remove the rear seats and spare tire, ice the intake and warm up the tires hard!
A supercharger would work too. 8 - 10 psi sounds about right on a stock engine. Anymore and you'll be getting forged internals put in your NEXT engine.
#29
ORIGINAL: nomocobra
yeah, your totally correct about the rods at high rpm's. but i would think that instant boost, would cause strain on the entire motor, when it first hits hard?
#30
So whats the opposition?
I see lots of people with these vortechs, I do drive to work everyday, after i get the s/c Ill probally get a cheap beater, but ill still drive to work somedays.
Essentially, Im not hurting anything aslong as i dont Exceed 8psi? Whats wrong with punching it everynow and then?
I just want to know before i save for this, if this is going to do damage even under moderate levels or will it still be a overall safe side for normal and some enthusiast driving.
