My Procharged Dyno Results! (Graphs included)
Well today I went to KC for a tune (SCT Chip) and new Lightning MAF install. After about 7 dyno runs we ended up with a fairly conservative tune (A/F= 11.0 @ 6K) with the final numbers at 390 & 414. Those are with the 8lb pully that due to weather today wasnt putting out almost 10lbs. Thats around 450 at the flywheel so i'm pretty happy with that for stock internals at this point as any more would def be breaking point with a single detonation. Anyways heres a few pics I took of the dyno sheets:
not bad for a little 281 with no pushrods....Thanks for looking!
RE: My Procharged Dyno Results! (Graphs included)
Close- its called Sunburst Gold, only offered in 00. For the rubber im just running Nitto 315 DRs right now, but when I go to the track I use a set of MT ET Drags (finally have the 31 spline to take it).
ORIGINAL: Machwon
ORIGINAL: 2000GT4.6
you went to KC? What shop did you have do tuning in KC?
MikeV- I have a 31 spline rear with 3.73s and upper/lower C/As. I knew the stocker 28s weren't going to hold up to the power/slicks so I upgraded them over the summer. now all thats left is the tranny...lol which is prob on its last leg at WOT. My car has 60K right now.
