If I get a tubular k-member, do I NEED tubular a-arms? If not needed, what are the benefits of getting them? I mainly want a K-member for LT's, so I would rather do a-arms later.
hal qa1 is a nice budget k member opens up a lot of room and alows you to runs your stock a arms I believe there is one other company that does it too i got mine from summit
You can run stock a arms with the QA1 k member but you will have to do some grinding to the a arms to make them fit. The instructions tell you how to do it.
yeah ox and code are right I did have a hard time runing my alignment in i had to my c/c plates like all maxed out and i got a cam that goes in the up lower strut to alow more camber alignment so i am at -.5 now and yes you do neet to grind the bolt but thats the easy part. if you do I will show you pics and help install it with word and advice i am sure you are too far away for me to go
I have been wanting to do that as well, anyone know about MM k member, lets say you use tubular a arms as well, do you have to go with coil overs then?
