HELP!!! Car Has Trouble Starting
RE: HELP!!! Car Has Trouble Starting
my car is having the same problem.. i checked the fuel pump and it is good i took the IAC off and cleaned it with some wd-40 and brake cleaner ... i didnt think to check the fuel filter cause i didnt think it could be the problem... have some one stand at the back of your car and listen for the pump when you turn the key to the on position dont start it just turn it... if you hear the pump it is more than likely not your problem i even made sure it is pressurizing properly... if you find out the problem send me a PM and let me know what it is so maybe i can figure mine out... i would take it to a mechanic but when it does start the idle is so wierd that i dont think it will make it there.. good luck man
sweet yeah the stock indash 6cd changer is crap. anyways back to my main concern, get the starter checked out? could my underdrive pulleys be playin a roll?
ORIGINAL: 02GT87
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
