What all should i have them do during a tune-up
i have a '99 manual GT. obviously the plugs. should i change the wires? should i change the fuel filter? i am getting it a tune up because its running a little rough. it has 95,000 on it and only 5k are mine.
RE: What all should i have them do during a tune-up
There technically are no wires. Its a coil pack system. The coils sit ontop of the plugs. If it was me i would change the coilpacks. I did that when i first got mine. But idk.
ok big time rookie here. i usually have someone help me do all the tune up stuff myself but im gonna take it in mainly cause im being lazy. how much should i expect to pay for a tune up with the fixins.
Basic Tune Up List
1. Fuel Filter every 10k
2. Air Filter every 10k
3. PCV Valve every 10-20k
4. Plugs every 60k
5. Belt
6. Oil Change every 3k
Those are the basics...the Coil Packs are kinda expensive so you might not want to do those
Here is a est price on the above list:
1. Motorcraft apprx. 10-12 dollars
2. Motorcraft apprx. 10-12 dollars
3. PCV goes for about 2-3 dollars
4. Motorcraft apprx 12-16 dollars
5. Gates apprx. 45-50 dollars
6. Motorcraft 5w20 blend 10 dollars + another Qt for about 2 dollars
Motorcraft Filter FL820S apprx. 3-4 dollars
I did not mention your cooling system but being that Winter is almost here.....Might want do at least check your levels and Color.
Hope this helps
4. Plugs every 60k
5. Belt
Hope this helps
