What to do and what NOT to do with Predator
I'm going to most likely order it tonight for my 2003 Auto GT. Now here what I know to do.
Max out timing for 93 octane
Firm up all shifts
Disable traction control ( I freggin hate it!)
Adjust cooling fan temps ( Whats stock temp? and what should I set it too?)
Delete top speed limiter
Now heres where I have questions..
Should I adjust the A/F Ratio, Rev limit or any other fuel tables? What else can be done?
Firm up all shifts
RE: What to do and what NOT to do with Predator
im buying mine tommorow if i knew i would tell ya but I hope u get awnsers so ill know. email me at tylerthorntonh4x@yahoo.com if you wanna give me any tips. mines for a '02 GT
ORIGINAL: stang2000
To do : buy an SCT
Not to do : buy a predator
To do : buy an SCT
the sct only offers a bit more adjustability really.... and it depends on what shops near u use to tune, i have the diablo and it works very well. plus i have a site where you can get them for 319 shipped to your door, if u want it lmk. thats where i purchased mine from.
I think they bacially have the same options...
Predator:
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off Switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
WOT Shift Pressure
Part throttle shift firmness
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
Disable EGR (use for off-road vehicles only)
Internet Updateable
SCT:
Fuel Adjustment Yes
Spark Adjustment Yes
Read / Clear OBD-II Trouble Codes Yes
Axle Ratio Selection Yes*
MAF Meter Selection Yes
Tire Size Selection Yes
Fuel Injector Size Selection Yes
Idle RPM Yes
Cooling Fan On / Off Temperature Yes
Disable Traction Control Yes*
Two Step On / Off RPM Yes*
Automatic Shift Control
Pre-Programmed with up to 3 tune files by your local SCT Custom Tuning Dealer*
I have diablosport and am very satisfied with it... Don't expect huge gains from either though (besides on supercharged or diesel vechicles).. remember your basically doing with a tuner what you did with a turn of a screw and distributor cap on older stuff..
Predator:
Idle (+/- 20%)
Raise Speed Limiter
Rev Limiter
WOT Shift Pressure
RPM Shift Points
Internet Updateable
SCT:
Fuel Adjustment Yes
Idle RPM Yes
The guy at pdi performance put mine 1% leaner and advance timing all the way on both 2-4000 and 4 +. Not sure that its a huge difference but... thats just what he did. I've read that 4.6's are a couple of points rich factory..
ORIGINAL: stang2000
To do : buy an SCT
To do : buy an SCT
You will get some people that say either one is good, and some will say get an SCT, but I've never seen anyone saying get a predator, so what do you think you should do?
