PISTON MISTAKE
RE: PISTON MISTAKE
Did the guy who built it Know you were running a SC? What gives, all blown engines use dished pistons to provide more combustion space. More room, more fuel/air cram=more power.
John
John
RE: PISTON MISTAKE
ORIGINAL: oxfordgt
You can use a thicker head gasket to drop your compression ratio if your reall worried about upping your boost. If you keep it at that compression you will need to run race fuel if you want to up the boost. With 10:1 you should be running 93 octane. Why did your engine guy say you can't run cams?
RE: PISTON MISTAKE
The thicker head gasket isn't the best solution but it is better then the cost of the rebuild. Their will be no timing issue with a thicker head gasket only if you shave the head to try to raise compression. Remember their are tentioners that can go in but can not push out more.
RE: PISTON MISTAKE
With a thicker head gasket the heads would be sitting higher. Correct me if I am wrong, but wouldn't the timing chains be spaning a larger distance changing their revolutions. It just seems like it would affect they way you time the engine.
RE: PISTON MISTAKE
Just dump the blower and get a nice size shot of nitrous for it. Nitrous loves compression. Probably the easiest thing to do without have to crack the whole motor open or blow it up running to much boost.
