SCT Tuner Question
RE: SCT Tuner Question
Just keep scrolling thru menus & you will find it. Cant see how you could miss it. No yo dont need the comp hookup. Use the up & down arrows to scroll. Its 12:30 here now. If I remember ill check mine when i get up. PM me if you like to remind me.
ORIGINAL: ForeverFord
You can't turn off T/C w/ your tuner. I was under the impression that you could when I bought mine but found out after that you could'nt.
Im on my way out @ this moment, cant find my instruction manuel. Plug it in to your car & start moving down thru menu & hitting select w/o changing any thing & you should be able to find the menu option. I am taking my tuner w/ me & I will go thru it when I get a few mins.
You have to start to program your car. plug tuner into port. scroll down to "program vehicle" option. Then start going thru menu, choosing your year & engine 1st then selecting other options either changing or just use select to skip over the option & you will eventually come to the 02 sensor & traction control options. For the stuff you dont want to change just use select w/o changing option. Hope this helps.
