New Trick Flow 2V Intake !!!
RE: New Trick Flow 2V Intake !!!
ORIGINAL: Nadelle
if its just a knock off of the bullet then probably not to much.
i would like to see them copy the LS6 intake, or somthing like the 3-valve intake for a two valve.
ORIGINAL: yoteehunter
Cast aluminum manafolds should sell for 150.00-450.00 bucks period. Every 4.6 manafold out there is way over priced and for the gains most have I think I'll just stick with my PI intake. Not to metion it isnt even out yet........so here we are again another over price peice that isnt even out yet, seems to be the trend with the 4.6 stuff. And then we wonder why were all playing catch up to the chevy guys.
Eldbrock does make a 4.6 manafold and it sux it is set up for a carb, apparently you would have to rig up your own elbow cuz they do offer it with injector bugs. They did this for those useing the 4.6 in a hot rod were a carbarator is easyer to use than F/I. There again just doesnt fit the mustang rep very well. Would should have a hellatious aftermarket. The 5.0 market took off like a rocket but the 4.6 market seems to be falling on its face with high prices and little gains. So......what we need is......some BIG *** AFTERMARKET HEADS, BIG *** INTAKES, BIG *** BORE BLOCKS, BIG *** CAMS, and at a resonable price. I will say the aftermarket for rebuilding the 4.6 with forged stuff is getting much better. I found a forged kit along with other stuff for super cheap the other day. It was almost as cheap as the 302 stuff. Oh almost forgot heres the link. http://forums.modulardepot.com/showthread.php?t=92066
ORIGINAL: djb1187
doesn the bullit have way more torque than we do?
The real advantage is FI. I have seen claims of 25-30 WHP with a stock bullitt intake on a FI car.
You will probably never see a 200 dollar intake for a 4.6L. Supply and demand here. You have to understand that the SBC intakes will basically fit on any 350. There are simply too many to count out there, and when you can sell thousands a year you can sell it cheap.
Just a side note, but from what I have seen aftermarket LS1 intakes are not that cheap, just the LS6 stocker swaps people do. I don't think you can find a new aftermarket intake for a LS1 for anything close to 300 bucks.
What kind of modification is required to put a Bullitt intake (or this new Bullitt-like intake) on an already FI'd 4.6?
I'm assuming the plumbing between the MAF and TB is the only difference, correct?
ORIGINAL: newb2000GT
The bullitt requires it's own t/b, and I don't think the rest of the intake tract will boltup to a bullitt t/b, but I could be wrong. Also, getting a bullitt is hard and expensive. I have seen em going for 1000+
Actually Edlebrock does have a Manifold for the mod motors 4.6.
Victor JR 4.6L SOHC EFI (up to 7500 rpm) Part #28385
Last time I called them, it was still in engineering mode. That was earlier in the year though. I was hoping for manufacturing mode, lol.
1-310-781-2222 ext. 2925
ORIGINAL: 2000GT4.6
Swapping to a bullitt intake won't gain much on a n/a car, unless you port the hell out of it. Stock vs stock a bullitt doesn't make much more power (5~) or torque than any other stock 99-04 GT.
The 2v PI intake is acutally a fairly good piece for a boltons only n/a car. This is why there hasn't been alot of companys making them, and why the gains are less than stellar when the aftermarket intakes are put on a basically stock or light boltons only car.
Since there isn't, why not just stick w/ the stocker??
JT
