My cluch squeeks
My cluch squeeks
Ok- Im driving hard, letting the Rpms rise up fairly hard, and shift it fast into the next gear.
When I spring off the clutch i hear a "cheeeeeep" like its slipping for a split second on a hard shift.
Does anyone elses do this?
RE: My cluch squeeks
ORIGINAL: 2002stang
Yep...Ford should be ashamed of themselve for building such a crappy car. My THROWOUT bearing makes a squeaking noise...and i think that's what your talking about....As soon as i put my feet lightly on the clutch the noise stops....I'm really angry about that...My wife old Hyundai has over 120,000 miles on it and she hasn't had any problems with her transmission...and i've had all types of problems with our mustangs.
ORIGINAL: DUB 6
ORIGINAL: 2002stang
ORIGINAL: USAMuscle
That's exactly what it is. It makes a high-pitched squeal until you press the clutch pedal, and it's always worse when the car is cold. At least it was for me. The part is only about $35 to replace, but you have to drop your exhaust and transmission to get to it, so it's a pain in the *** process for a small part that takes about 10 minutes by itself to replace.
ORIGINAL: DUB 6
ORIGINAL: 2002stang
Mine is making kind of a dry whirring when the clutch is engaged in neutral... sounds fine when I put the clutch in. I checked trans fluid, and it's full... I wouldn't call this a squeal, but maybe that's what I have to look forward to as it gets worse. Woohoo, Ford!
ok on the squeak, I have only 19k and im covered under warranty.
Should I see if i can get the bearing replaced? Im sure ill have to do without my car forawhile...
If its not going to **** up, then im not gonna go,
what does everyone think
