What size MAF are you running?
I currently have an 85mm MAF sensor. I think thats way to big, the stock is 65mm, correct? What size are you guys running and did you notice any increase when you switch it? I am thinking about going with mabye a JLT CAI and putting the stock MAF housing back on. But my SCT flash tuner is programed for the 85mm, (I had it dynoed tuned with my current set up) does anyone know if I can change it, with the flash tuner back to stock?
RE: What size MAF are you running?
i have the stock maf with my supercharger im pegged out at 5 grand flat gona get the biggest blow threw i can find so i can put a blow off valve on . i did buy a lightning 90m and it wouldnt even hook up after they said it would and that would be jdm engineering
I know there is a company out there that makes and adapter our plug to the lighting plug because they are different I think blue oval industried has it not shure look around
ORIGINAL: stangy004
ORIGINAL: Rantheman
thanks bro im gona have to check on that
ORIGINAL: stangy004
