Fuel pump for leaded gas
RE: Fuel pump for leaded gas
Gotcha.. In fact, from what I know, using the Leaded stuff can cause fires..
I forgot about O2's..
Now, Alcohol.. That's something that may require different fuel systems...
JT
JT
ORIGINAL: GodAmGT00
JT
JT
ORIGINAL: JD1969
leaded fuel will not cause a fire anymore than regular fuel. All lead does is to help raise octane and act as a lubrcant and cushion on the valves. Alcohol will require some changes in the fuel system to run.
ORIGINAL: GodAmGT00
JT
JT
Maybe I'm still way off, but I thought that was part of it...
JT
Na it just will clog the converter. I think you would notice how terrible the car was running long before it was clogged bad enough to cause a fire. I would hope so anyways
Okay.. It makes all sorts of sense now...
In fact I want to use some Lead Additive every few tanks next year on the new engine to make sure that everything stays copasetic..
I'd say it's even better for your engine that Alcohol, when it comes to Octane stabilization..
JT
JT
