how to get 12.999999 naturally aspirated?????
i have a 2000 mustang gt. 5 speed with following mods! 4.10 gears, 75mm tb, 75mm plenum, bbk o/r x pipe, bbk longtube headers, sct x cal 2 tuner, flowmaster weld in mufflers, jlt cai, clutch quadrant, firewall adjuster, steeda udp's , steeda tri ax.
i want to get 12.99999 out of my car on motor without heads and cams upgrade! i have nitrous on the car but i want to achieve 12.999 n/a.
what will it take to get it down there. i ran a 13.5 on street tires! i recently got nittro d/r's but what else would it take?
RE: how to get 12.999999 naturally aspirated?????
I think it's possible with just the drag radials, but unlikely. Maybe some suspension upgrades to perfect the launch? Control arms, subframe connectors, drag shocks...that kinda stuff
if you think you can get into the 12s with a n/a 2 valve without increasing airflow and volume in the top half of the motor then let us know when you do please. we would all like to know!! the only way to get closer would be to spend mad amounts of money on suspension but i seriously doubt you would shave off enough time needed to get you there. it would take more money for that than it would heads and cam work. its a question of physics, how do you make something go faster without dramatically improving power?
Well, I said it was unlikely but I still think it's possible. If he makes a perfect run. Meaning the track conditions are perfect, low altitude, low temperature and humidity, sticky road, wind blowing in his favor, he nails a perfect launch and shifts like a pro. VERY unlikely, but still possible.
2010 Blue Ball Award Recipient
Shave some weight (nothing dramatic, but anything you can spare)
Work on your launches, and shifts,,
A full bolt on N/A 2V GT should be able to do 12.9s with a 1.8 range 60'
