adjusting clutch
adjusting clutch
I am about to be finished putting a King Cobra clutch in my car. I just need to put the exhaust and driveshaft in. I pushed on the clutch and there is alot of play in it, and gets stiff at the last 2 inches of petal range. I know its a self ajusting clutch but I need to adjust it more. How do I adjust it since the new clutch is in?
Jay
Jay
RE: adjusting clutch
dont adjust it yet
leave at least 2 inches of play
once the clutch wears down it will raise on its own.
If you adjust tight it will sit on the TOB and wear it down..... Thats what my mechanic told me because i had king cobra installed and it engaged an inch from the floor
did you replace the quadrant?
depends on what kind of adjuster you have?
behind dust cover?
in firewall?
factory is adjusted just by pulling pedal towards you...
if inside dust cover you just adjust the bolts until your satisfied.
I have never used a firewall adjuster so i could not tell you.
behind dust cover?
in firewall?
ORIGINAL: 99gtstang
dont adjust it yet
dont adjust it yet
leave it? it doenst even feel like the clutch disengages when I push the petal like it gets stiff so far down towards the floor. like maybe a inch off the floor.
Jay
Jay
how do u adjust the stock clutch...I tried pulling it towards me but that didnt do anything. I still dont know if i have a factory or aftermarket clutch. I just know it feels like its not completly disengaging and it engages about 1 inch from the floor
ORIGINAL: djb1187
Put in first gear
Pull up on the clutch until you hear a snap sound
Push clutch to the floor
Your done
Later
It may take more than once to get it adjusted. Put the procedure below will adjust for you.
ORIGINAL: blownbayou
Car OFF
Put in first gear
Your done
Later
ORIGINAL: djb1187
Put in first gear
Your done
Later
