F/I and Suspension
RE: F/I and Suspension
ORIGINAL: handyandy
Anyone have the pro kit without LT's? I wanna know if I could get one and still have okay clearance for speedbumps with just a catback.
And besides lowering. To go with a pro kit, or instead of a pro kit, whats just ONE thing that wouldn't mess up a bunch of stuff. Lower Control Arms? I dunno.
EDIT: I just looked up the pro kit and some website has this...whats the difference between the "drag launch kit" for an extra 20 bucks to the regular lowering springs?
And what exactly does "progressive" mean?
Pros Cons of SC
Pro: Cost less than TC, output is throughout RPM range, no turbo lag
Cons: Prone to belt breaking/slippage at higher PSI, Less HP per PSI of boost than Turbo
Pros Cons of Turbo:
Pro: More power per psi than S/C
Con: Cost, turbo lag, Boost does not get maxed until you reach higher RPMs (which is why most imports run them)
I'm sure there are some I've missed, but those are the main points.
Pros Cons of Turbo:
ORIGINAL: Derf00
Pros Cons of SC
Pros Cons of Turbo:
Pros Cons of SC
Pros Cons of Turbo:
What is that just a terrible generalization?
The real reason imports run turbos is because its ****ing easy to.. its easy to just run a 4cyl header into a turbo and have room for a turboback exhaust.
Why it sucks to do it on a mustang. Theres no damn room; it has a v8 in it and the exhaust comes out the sides and back not out the front. Not that it cant be modified but the way the engine sits theres not much room. To make a turbo system possible on a mustang its atleast a must to have at tubular Kmember. Full coilover kit you're looking at 750+ easy. Also its a lot harder to run piping from two different sets of 4 ports goto a set of turbo's or combine tubing into one and run a big single, the have room yet to run the exhuast out the back and have an intake.
^thats probably poorly worded but thats the real reason.
I only plan to drop it 1.5 inches. Does that close up the 4x4 fender-tire gap pretty well? Is it enough? And what do C/C plates do.
Also, if I drop it, can I still get Lower Control Arms? Are those beneficial?
I have Eibach Pro Kits (lowered about 1.5") and my exhaust scrapes going over speedbumps if i hit it at the wrong angle or have a lot of people in the car. I had 4 people (including myself) in the car tonite ans scraped over 3 speed bumps, even tho i was barely even moving when i went over em. And all I have is a catback...I have yet to purchase my LT headers.
As for suspension, ive heard that full length subframe connectors are a worthy investment. Not any downsides to them that i can really think of...outside of maybe just a little more noise.
Matt's 95 Stang
10-05-2015 07:16 AM
