Yea you can do it yourself. Google it a little bit to find out. Its some odd **** you do with the key in the ignition. This might be wrong but its somehting like this I THINK: Put the key in the ignition and turn it to the third position, then turn it to the fourth position and back to the third. If you do this ten times or something like that the doors will lock on and off as a signal it worked. From there I cant remember But if you look online you can fid how to do it. But it is possible! it might even say how to on your manul Im pretty sure its on there too. Check
Will this work on all sn95? or more specific... If I go out side and try to do this to my 96 is it going to have any ill effects like stop working all together? lol cause that would suck!
