Underdrive pulley?
Old 07-29-2004, 01:50 PM
OUZBnd
OUZBnd's Avatar
Default Underdrive pulley?
Im thinking about a underdrive pulley kit, they seem cheap enough but are they effective? Is it worth the dough? How long/hard is the install? Do i need any special tools? what brand do you reccommend? and does the stock belt work with them?
Thanks!
OUZBnd is offline
Old 07-29-2004, 02:04 PM
2000GT4.6
2000GT4.6's Avatar
Default RE: Underdrive pulley?
Underdrive pullys are effective, but it is not yank you back in your seat effective. You will notice a differece on a dyno, and perhaps a small amount on the street.
It is a fairly easy install, shouldnt take more than about a hour or two. The biggest problem that I had was the alternator pully bolt didnt want to come off. I ended up having to take off the radiator resivour tank (like 3 bolts) and push it aside so I could get the impact directly inline with the bolt.
To install the underdrives you must have a good impact wrench and a 3 bolt pully puller. A regular pully puller wont do. I also recommend having a big set of slide jaw pliers if the alternator pully decides to be a pain to remove and spins on the belt.
I got steedas and was pleased with them. No problems from them whatsoever and they are looking nice after a couple weeks of use.
BTW the stock belt will work with them, but I decided to get a belt one size smaller. It was a very tight fit, but there is no slippage at all now.
2000GT4.6 is offline
Old 07-29-2004, 02:10 PM
OUZBnd
OUZBnd's Avatar
would you reccomend something else before the pulleys? im considering either a densecharger/maf/tb/plenium or a catback/midpipe also, but i dont want to drop 800-900 in my car if i wont notice much differences. the only mod now is 3.73's.
What do you reccommend i go with next? the pulleys were just a though because they are so cheap.
02 gt 5 spd
thanks!
OUZBnd is offline
Old 07-29-2004, 03:27 PM
Js281GT
Js281GT's Avatar
Get a mac pro-chamber, you will gain like 2 tenths.
Js281GT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
spdeplayer2
10-24-2015 09:45 AM
FivePointToTheOh
09-29-2015 12:53 PM
mikesr4565
Suspension
09-21-2015 10:26 AM
GimpyHSHS
09-18-2015 12:27 PM
Quick Reply: Underdrive pulley?
