real hood scoop conversion
i have a 04 gt and i want to make my hood scoop real... is this a good idea? i have connections to open the hole for free...
just wondering if something bad can happen or if its a good idea... thanks
RE: real hood scoop conversion
I heard a number of opinions. If you cut it, you lose strength in the hood. You wont get any hp gains, seeing as how the air intake is in the fender. However, I was considering doing this just for a heat vent to cool the damn engine. With the tiny grill the stangs have, its really hard to get air moving inside the engine bay, and a big hole on top would definatly help. But, youre also gonna get a ton of water in there when it rains or you wash it. Soooooo, there are pros and cons. Its up to you what you want to do.
Matt
Matt
It's not functional even with a hole cut in it. Your choice, your car. It will not benefit you in any way, but if you're just going for a different look, then maybe that's the ticket, besides the excess water that may get into the engine.
ORIGINAL: stang2000
It would be kind of functional, just as a means for heat to escape from the engine bay, which might...and i say again might.....do something for performance.
well my problem is i put a billet grill on it and the air going all in the scoop messed up my scoop and broke it a little bit..
and now on the highway it flaps up and down and its not a pretty sight... i think it might break off soon so i wanted to open it up and
make the drag go away and reglue the broken peice... i reglued it before but the high speed winds breaks it again... thats why i want to open the hole....
Well pull it off before it flys off and smashes through your windshield and decapitates you, or hits someone elses car. Figure it out with the thing not an immediate threat to anyone on the road way.
IM agreeing wiht all teh others. I doubt highly it will do anything for you, and its not worht your money to get the mach 1 conversion. Why dont you just buy a new hoodschoop and say screw the billet insert
I dont know about that whole functional hood scoop doing it yourself. I have a kit that is made by March called a ram air kit. The kit runs from under the bumper up the fender directly to the intake. It is a pretty basic setup and somewhat cheap, however there was some minor trimming on the lip under the bumper. That would be an option for maby a few hp and more air circulation. If not i would do the Mach 1 kit.
