exhaust help asap!!
exhaust help asap!!
Alright my catalytic converters are shot so i need to buy new ones and im going to buy a new cat back exhaust kit, the thing im confused about is that i have a bassani x-pipe on my car..do i need special cat converters? and will any cat back exhaust system fit on my car with the x pipe thats on it?
RE: exhaust help asap!!
ORIGINAL: 98GTstang
pretty sure the stock ones are shot, the bassani x pipe doesnt have cats on it. will a univeral cat work? or should i get a high flow cat?
high flow is better then traditional cats.
You have 2 options, you can either cut and weld the new cat's into the Bassani X-pipe set-up, or you can get a cat-back system that includes the cats. I already have the x-pipe and hi-flow cats on my GT and my cat's are bad, so I'm fixing to cut and weld new one's in and build my own custom cat-back system. Just make sure if you do this you use HI-FLOW cats or you just screwed the entire purpose of having a performance exhaust.
I may be retarded or not reading this right........ but the cats are gonna be on your midpipe, so how can u have shot stock cats, when u dont have a stock midpipe, im not sure if im missing something here. If ur cats are shot there on ur bassani midpipe so just get a new mid pipe.......
ORIGINAL: 98GTstang
ORIGINAL: 98GTstang
