03 Marauder injector flow rate?
Hey guys-
I'm new to this forum and have a question about some injectors I just bought. They are supposedly off an 03 Marauder. The numbers on the injectors are 2C5E-A4A and 9F593 242. Can anybody confirm these are off an 03 Marauder, and what the flow rate of these injectors are? They will be going into a 4.6L stroker for my Jeep.
RE: 03 Marauder injector flow rate?
ORIGINAL: StockD15b
well by the way the answers are just flowing in (lol no pun intended) it might just be your best bet.
I know it's a little late to be posting, but I own a 6 cyl '00 Mustang that a previous owner had put a marauder motor in. There's good news and bad news. The good news is that your part number is the exact same as mine, so it is, indeed a Marauder part number. The bad news is that I can't figure out what the flow rate is myself. It's basically a Mach I Automatic engine, which comes stock with 24# injectors, so I'm guessing they're 24's as well. I'll try to find this post again if I figure it out.
Its not that us "mustang guys" don't know about fuel injectors, its that no one is going to memorize mercury part numbers. However, I found this:
fuel injector website this mustang guy found
Looks to me like they are 24#ers. I have read that this same injector is actually 21# though,
This part number (2C5E-A4A) matches up to that of injectors from either a 2003 Mercury Marauder or Lincoln Aviator. It is not the same 24# injector us "mustang guys" are familiar with that came on 01.5 - 04 GT's, which would be part number (XR3E-C5B), the little pink ones.
Part number (2R3V-B5A) would be the 39# from 03-04 cobra's, this would be ideal for your setup, however I don't believe they will plug up without some custom fabrication of your harness.
Sorry about the first impression... jeep guy
This could be you:
This could be you:
Just a question out of the blue, but why in gods name would you run a 4.6L stroker in your jeep? Are you simply trying to go insane on the build cost, or do you have something presonal against a pushrod build?
Seriously, if your starting with an empty plate why would you put a ford modular into a jeep? Not ony do the 4.6Ls not make alot of down low tq, but its just insanely expensive to do a motor build. 350 chevy or 351W ford FTW!
Edit: The 24 pounders you have should take you quite a long ways in a n/a 4.6L car.
Just found the same website this morning. That's where I got my information. Should have posted it, sorry about that. I think the modular motor in the jeep rocks! I agree you're giving up some torque over a fairly inexpensive SBC Stroker motor, but sometimes availability rules!
ORIGINAL: Bl00ByU
Unless we are talking about a drag race setup (and then, why are you starting with a jeep lol) its a terrible combonation.
Nothing says getting stuck in the mud and being unable to crawl rocks etc like a high revving torque lacking small displacement motor.
