need help on SC setup
im saving for a SC and curious as to what mods do i need to make it compatible with my engine or does it come with most of everything,only thing i know of having to buy is the injectors,well as of now i just got this stang and put ngk spark plugs,msd spark plug wires,removed the air silencer,edlebrock high flow fuel pump,mobile synthetic oil.whats the name of the automatic transmission on my car and where can i go to get after market parts for it(shift kits,tourque converter).what are the reccomended suspension mods or braking mods be best for me, i want everything to be righ when i do this,all advice is appreciated.
RE: need help on SC setup
For starters, we'll need to know what car we're talking about. I'm guessing a 4.6 Mustang based on the forum we're in but tranny and many other things are based on the year.
Most SC kits come with everything you need for the SC itself but you will probably want to get some suspension components like lower control arms and subframe connectors at the minimum. Manual cars need a clutch usually for the increased power but I'm not sure what you will need with your auto. You mentione a convertor which is never a bad idea.
Do people with blowers, especially centri cause that is what im looking at, get different beerfed up transmissions or do the stockers work fine? Cause I just spent 1800 on a tranny rebuild and don't wanna have to do it again.
ORIGINAL: ASUSMC
jwog666
12-27-2021 08:09 PM
