5w20 vs 5w30
5w20 vs 5w30
My car calls for 5w20 to be used, but while at my local Walmart I noticed that the 5 quart Mobil 1 synthetic was on sale for 19.99 so I coudnt pass it up. Will using this cause any damage to my car's engine? Secondly I have heard of people using tranny fluid to flush the engine. Any experiences/thoughts?
RE: 5w20 vs 5w30
5w-30 can be used in the place of 5w-20. The difference will be in mileage.
As for using ATF to flush an engine, I have successfully done that a couple times. Basically, you substitute 1 quart of ATF for a quart of motor oil. You'll want to change the oil after a couple hundred miles.
A better idea is to use high quality oil and change it as recommended by the oil manufacturer.
RE: 5w20 vs 5w30
ORIGINAL: pallidamors
So is there any benefit from flushing the engine using 1 quart of ATF in the oil or is it dangerous/waste of time? BTW my car just hit 27 k on the odometer.
RE: 5w20 vs 5w30
If 5w 20 is going to damage the engine, then y does for recommend it?
