No traction control on 04' GT WTF
RE: No traction control on 04' GT WTF
ORIGINAL: 4.698GT
Thats completely wrong. I have ABS in my car and it has no traction control.
ORIGINAL: SOHCtimes2
Dude, what are you talking about? Unless ABS stands for something other then Anti-Locking Brake System... I don't have traction control but I most certainly do have ABS. Hell my old 94 Probe GT didnt have traction control but it had ABS. Perhaps you mixed up your letters with something else? Though I can't think of what...
Traction control has nothing to do with ABS. If you let it kick in you will see that your brakes don't slow the car down. I think that traction control is a bunch of crap anyways. what slows the car or stops it from sliding is the fuel management. rpm with no acceleration, or too much rpm with no acceleration. the switch takes the torque away from the car. makes it to where you cant go. and sometimes when you want it to go, the car stops it from that so it is a piece of crap. Don't even worry about not having it.
with traction control on... i held a burnout, and it kept spinning into 2nd (auto)... and it still spins... the only time I've ever seen it work was when I tried whipping her around, and I forgot that it turned back on, so I cut the wheel, gunned it, and the tires just chriped along the ground... In other words... it's always OFF in my car.
ORIGINAL: stangc83
ORIGINAL: ShadowDrake
You clearly don't understand exactly how the traction control works. Uses the ABS sensors to detect wheelspin. Uses the ABS system to pulsate the rear brakes to help control that wheelspin... it'll also retard the engine timing when the traction control system is active. Without the ABS sensors to detect the wheelspin, and the main module to pulse the brakes, the traction control system would be useless.
Be glad you dont have it. It almost got me killed a few times. One time a pulled out to cross an intersection when it was wet, spun the tires on some sand so the tc cut the throttle so I couldnt go. I had to reach down to turn it off so I could get out of the way of an oncoming car.
Ummm....I was say dude what are you talking about referring to you saying that the cars dont have ABS if they doint have traction control....I know exactly how traction control works.
Clearly you do not, a car with without ABS will not have traction control. Why because it uses the ABS module along with its own algorithim to detect that the wheels are slipping.
Its pretty much the inverse of ABS. ABS and traction control have everything to do with eachother; its almost the same technology and TC needs ABS to work.
ORIGINAL: czwalga00gt
