Subframe Connectors
Subframe Connectors
Im looking to get some subframe connectors, and I was wondering what the difference was between $120 big brand (Steeda, MM) ones and the $50 ones on Ebay? They look very similar. If you have subframe connectors, what brand did you go with and how are they? I was considering the ones that could bolt and weld in. This way I could go ahead and bolt them in right away, and then weld them in when I got a chance. Would I see any difference with only bolting them in verses stock w/o them? I saw some MAC ones for $50 that could do both...
RE: Subframe Connectors
i have some MM full length weld in subframe's... they did a huge difference in body flex.. i would definatly weld them in for the best benifit.. also try to get some that are full length for more support...
You'll see the difference with just bolting them in. They might be given some room to flex just bolted in, but it'll still be a gigantic improvement over stock. I'd just hang on and get them welded in place.
the MM full length ones and they are great. best suspension mod i did and you can really tell a difference.
i'd get full length ones either way you go but i recommend the MM ones just from experience.
i have a set of Kenny Brown full length weld-ins that i still have never gotten installed...you guys think it would run about what 50 bucks for install if that?...is it true that you can't run side-exit exhaust with them? judging by that pic it seems true...also do you guys who have them feel more of a "difference" in handling or more when launching?
ORIGINAL: laserred38
