Upper/ Lower control arms install.........
My car will be in the garage for the next 5 months so im going to be doing some work. How much of a job is it to do the U/L control arms? anyone wanna give me a quick how to?.....I also want to swap back in my stock rear springs. the H&R sports are too damn low....this is my 2002 GT btw
RE: Upper/ Lower control arms install.........
It's really not that hard, but takes up some time. You'll need a lift or stands and a floor jack. I took my time and did it in 5 hours, but I went really slow. I recommend doing one arm at a time starting with the uppers. The lowers can suck due to the forward mount bolt. Tricky if you don't remove/loosen the cat back.
All in all, it was not too bad, but I did have a lift. Definitely worth the effort.
Me any my buddy put mine on in about 2 hours and thats with my driving around in between messin around. No lift, but we had 3 jacks. u will need 2 to do it on the garage floor. I only did lower so u should do uppers first most likely. Its pretty straightforward, the tricky part is u need to put a jack under the diff (NOT the round part!!!!, up on the flat spot towards the driveshaft). you will have to jack it up to tilt it a bit to enable you to get the control arms front bolts back in. I didnt see why until I did the install and then It was obvious what we had to do haha.
+1 for doing one at a time. prob neet 2 jacks. Like everyone said the front bolts on the lowers are a pita, but its not to bad of a install. it helps to have somone to help also
breaking
10-02-2015 01:27 PM
