You realize they are welded on and it is not a simple un-bolt and bolt the new one on. Sorry I am not sure where to get one except through Ford. I just wanted to point that out. Good Luck
You might be able to bang that out and then use bondo to smooth everything out. It isn't the best solution but it would be a lot cheaper and a lot less work.
you dont need a new panel just fund a good body shop have them handform it it doesnt look that bad at all no need to spend that much replacing it and paying someone to weld one on
