lca/uca
Old 10-31-2006, 02:01 AM
handyandy
handyandy's Avatar
Default lca/uca
who makes good lower/upper control arms? If I put them in would it mess up any other suspension components, or would they just be beneficial? Do they help daily handling as well as traction?
handyandy is offline
Old 10-31-2006, 02:18 AM
Fryguy22
Fryguy22's Avatar
Default RE: lca/uca
you won't notice much of a handling improvement due to the fact that it doesn't help stabilize the car much laterally. however, you will notice a great improvement in wheel hop. Granatelli (sp?) makes a good set. Check them out on ebay.
Fryguy22 is offline
Old 10-31-2006, 02:22 AM
BleedinBlue
BleedinBlue's Avatar
Default RE: lca/uca
Like these Granatellis?????? These seem too cheap to be true. Is it important for them to be adjustable?
BleedinBlue is offline
Old 10-31-2006, 03:04 AM
whty98
whty98's Avatar
Default RE: lca/uca
The best set up IMO would be Ford Racing Uppers and then Maximum Motorsports lower. Damage can be done due to too stiff of upper control arms bushings to the torque boxes. Adjustables would be mostly useful for drag racing and track, so not needed for street use. MM's site is a good learning place
whty98 is offline
Old 10-31-2006, 04:12 AM
hdawg06
hdawg06's Avatar
Default RE: lca/uca
ORIGINAL: BleedinBlue
Those are good control arms from what I've heard. If you are wanting to spend the extra money, get some Adjustable UCAs so you can change the pinion angle, and regular LCA.
hdawg06 is offline
Old 10-31-2006, 09:17 AM
04BlueGT
04BlueGT's Avatar
Default RE: lca/uca
I have those same granatelli CAs and they are fine. As long as you have poly bushings, the torque boxes will be fine. Using CAs with spherical bushings is not advised unless you fully weld the boxes and/or install plates in the boxes. Welding is probably easier.
04BlueGT is offline
SON OF 68
03-07-2013 08:35 PM
Stone629
The Racers Bench
10-15-2011 10:25 PM
demighost
11-15-2010 01:55 PM
a_penquin
02-10-2010 05:55 PM
demighost
02-07-2010 10:04 PM
Quick Reply: lca/uca
